عدد المساهمات : 18745 التقييم : 34763 تاريخ التسجيل : 01/07/2009 الدولة : مصر العمل : مدير منتدى هندسة الإنتاج والتصميم الميكانيكى
| موضوع: كتاب SOLIDWORKS 2016 - Learn by Doing 1 السبت 03 أبريل 2021, 12:32 am | |
أخوانى فى الله أحضرت لكم كتاب SOLIDWORKS 2016 - Learn by Doing 1 Tutorial Books
Table of Contents Chapter 1: Getting Started Starting SOLIDWORKS User Interface Quick Access Toolbar Menu CommandManager Features tab Evaluate tab Sketch tab Assemble tab Drawing Environment tabs Sheet Metal tabFeatureManager Design Tree Status bar View (Heads Up) Toolbar Shortcut Menus PropertyManager Breadcrumbs Mouse Functions Customizing the CommandManager, Shortcut Bars, and Menus Chapter 2: Modeling Basics TUTORIAL 1 Opening a New Part File Starting a Sketch Adding Dimensions Constructing the Base Feature Adding an Extruded Feature Adding another Extruded Feature Saving the Part TUTORIAL 2 Opening a New Part File Sketching a Revolve Profile Constructing the Revolved Boss Constructing the Cut feature Constructing another Cut feature Adding a Fillet Saving the Part TUTORIAL 3 Opening a New Part File Constructing the Cylindrical Feature Constructing Cut featureSaving the Part TUTORIAL 4 Applying Draft Saving the Part Chapter 3: Assembly Basics TUTORIAL 1 Opening a New Assembly File Inserting the Base Component Adding the second component Applying Mates Adding the Third Component Checking the Interference Saving the Assembly Starting the Main assembly Adding Disc to the Assembly Placing the Sub-assembly Adding Constraints Placing the second instance of the Sub-assembly Saving the Assembly TUTORIAL 2 Creating the Exploded View Creating Explode lines Chapter 4: Creating Drawings TUTORIAL 1 Opening a New Drawing File Generating the Base View Creating the Section View Creating the Detailed View Creating the CenterlineSpecifying Dimension Settings Retrieving Dimensions Adding additional dimensions Saving the Drawing TUTORIAL 2 Creating a Custom Sheet Format Starting a New drawing Generating the Drawing Views TUTORIAL 3 Creating the Isometric View Generating the Exploded View Creating the Bill of Materials Creating Balloons Chapter 5: Sketching Creating Rectangles Creating Polygons Relations Merge Horizontal Vertical Tangent Parallel Perpendicular Midpoint Automatic Relations Deleting Relations Hiding Relations Sketch Numeric Input Replace EntityMake Path Path Length Dimension Convert Entities Midpoint line, Perimeter Circle, and SketchXpert Ellipses Partial Ellipse Conic Move and Rotate Entities Rotate Entities Copy Entities Scale Entities Trim Entities Extend Entities Offset Entities TUTORIAL 1 Sketch Fillet Sketch Chamfer Mirror Entities Stretch Entities Circular Sketch Pattern 3D Sketch Chapter 6: Additional Modeling Tools TUTORIAL 1 Constructing the Helix Adding the Reference Plane Constructing the Sweep feature TUTORIAL 2 Constructing a Revolved Cut Constructing a Mirror FeatureTUTORIAL 3 Creating Sections and Guide curves Creating another section Constructing the swept feature Constructing the Extruded feature Adding Fillets Shelling the Model Adding the Indent feature Adding Threads TUTORIAL 4 Constructing a cylindrical shell Adding a Slot Constructing the Axis Constructing the Linear pattern Constructing the Circular pattern TUTORIAL 5 Constructing the first feature Constructing the Second Feature Constructing the third feature Inserting Holes Adding Chamfers TUTORIAL 6 Constructing the first feature Constructing the Extruded cut Making the Curve Driven Pattern TUTORIAL 7 Start a new part file Creating the second feature Adding Cosmetic ThreadsCreating Configurations Table TUTORIAL 8 Creating the First Feature Creating the Extruded surface Replacing the top face of the model with the surface Creating a Face fillet Creating a Variable Radius fillet Shelling the Model Creating the Mounting Bosses Creating the Vent Feature Chapter 7: Sheet metal Modeling TUTORIAL 1 Opening a New File Constructing the Base Flange Adding an Edge flange Constructing the Miter Flange Closing the Corners Adding Corner Reliefs Adding a Tab feature Adding a Jog Unfolding the bends Creating Cuts across bends Folding the Unfolded bends Performing the Forming Operations Making the Linear Pattern Adding a Hem Adding a vent Adding Sheet Metal Gussets Making a Fill PatternChapter 8: Top-Down Assembly Creating a New Assembly File Creating a component in the Assembly Creating the Second Component of the Assembly Creating the third Component of the Assembly Adding Bolt Connections to the assembly Patterning components in an assembly TUTORIAL 2 Creating Smart Mates Creating the Limit Mate Creating the Slot Mate Chapter 9: Dimensions and Annotations TUTORIAL 1 Creating a Model View with Center Marks Creating Centerlines and Center Marks Editing the Hatch Pattern Applying Dimensions Placing the Datum Feature Placing the Feature Control Frame Placing the Surface Texture Symbols Additional Exercises Exercise 1 Exercise 2 Exercise 3 Exercise 4 Exercise 5 Exercise 6
كلمة سر فك الضغط : books-world.net The Unzip Password : books-world.net أتمنى أن تستفيدوا من محتوى الموضوع وأن ينال إعجابكم رابط من موقع عالم الكتب لتنزيل كتاب SOLIDWORKS 2016 - Learn by Doing 1 رابط مباشر لتنزيل كتاب SOLIDWORKS 2016 - Learn by Doing 1
Alaa Aldeen Othman مهندس تحت الاختبار
عدد المساهمات : 1 التقييم : 1 تاريخ التسجيل : 12/10/2021 العمر : 27 الدولة : سوريا العمل : مهندس ميكانيك الجامعة : دمشق
| موضوع: رد: كتاب SOLIDWORKS 2016 - Learn by Doing 1 السبت 16 أكتوبر 2021, 9:23 pm | |
| موضوع: رد: كتاب SOLIDWORKS 2016 - Learn by Doing 1 الإثنين 06 ديسمبر 2021, 2:39 pm | |
- Alaa Aldeen Othman كتب:
- الملف المضغوط لا يفتح
الروابط و الملفات مجربة وتعمل عند كل الأخوة المهندسين بدون مشاكل المشكلة في الغالب عندك أخي جرب تفعيل أو تحديث أو تغيير برنامج فك الضغط بالإضافة الى تعريف اللغة العربية لنسخة الويندوز الخاصة بك و تأكد من أنك وضعت كلمة المرور بشكل صحيح قم بنسخها ووضعها كما هي دون تغيير في حجم الأحرف أو المسافات يرجى مشاهدة هذا الفيديو لتوضيح الصورة أكثر https://www.youtube.com/watch?v=E54toK7rO6E |
