عدد المساهمات : 18660 التقييم : 34550 تاريخ التسجيل : 01/07/2009 الدولة : مصر العمل : مدير منتدى هندسة الإنتاج والتصميم الميكانيكى
| موضوع: كتاب Machinery's Handbook 29th Edition الجمعة 07 يوليو 2017, 12:02 pm | |
أخوانى فى الله أحضرت لكم كتاب Machinery's Handbook 29th Edition By Erik Oberg, Franklin D. Jones, Holbrook L. Horton, And Henry H. Ryffel
Each section has a detailed Table of Contents or Index located on the page indicated PREFACE v TABLE OF CONTENTS vii ACKNOWLEDGMENTS ix MATHEMATICS 1 • NUMBERS, FRACTIONS, AND DECIMALS • ALGEBRA AND EQUATIONS • GEOMETRY • SOLUTION OF TRIANGLES • MATRICES • MANUFACTURING DATA ANALYSIS • ENGINEERING ECONOMICS MECHANICS AND STRENGTH OF MATERIALS 147 • MECHANICS • VELOCITY, ACCELERATION, WORK, AND ENERGY • STRENGTH OF MATERIALS • PROPERTIES OF BODIES • BEAMS • COLUMNS • PLATES, SHELLS, AND CYLINDERS • SHAFTS • SPRINGS • DISC SPRINGS • FLUID MECHANICS PROPERTIES, TREATMENT, AND TESTING OF MATERIALS 369 • THE ELEMENTS, HEAT, MASS, AND WEIGHT • PROPERTIES OF WOOD, CERAMICS, PLASTICS, METALS • STANDARD STEELS • TOOL STEELS • HARDENING, TEMPERING, AND ANNEALING • NONFERROUS ALLOYS • PLASTICS DIMENSIONING, GAGING, AND MEASURING 608 • DRAFTING PRACTICES • ALLOWANCES AND TOLERANCES FOR FITS • MEASURING, INSTRUMENTS, AND INSPECTION METHODS • SURFACE TEXTURE TOOLING AND TOOLMAKING 754 • CUTTING TOOLS • CEMENTED CARBIDES • FORMING TOOLS • MILLING CUTTERS • REAMERS • TWIST DRILLS AND COUNTERBORES • TAPS • STANDARD TAPERS • ARBORS, CHUCKS, AND SPINDLES • BROACHES AND BROACHING • FILES AND BURS • KNURLS AND KNURLING • TOOL WEAR AND SHARPENING MACHINING OPERATIONS 1004 • CUTTING SPEEDS AND FEEDS • SPEED AND FEED TABLES • ESTIMATING SPEEDS AND MACHINING POWER • MICROMACHINING • MACHINING ECONOMETRICS • SCREW MACHINES, BAND SAWS, CUTTING FLUIDS • MACHINING NONFERROUS METALS AND NON-METALLIC MATERIALS • GRINDING FEEDS AND SPEEDS • GRINDING AND OTHER ABRASIVE PROCESSES • CNC NUMERICAL CONTROL PROGRAMMING MANUFACTURING PROCESSES 1328 • SHEET METAL WORKING AND PRESSES • ELECTRICAL DISCHARGE MACHINING • IRON AND STEEL CASTINGS • SOLDERING AND BRAZING • WELDING • LASERS • FINISHING OPERATIONS TABLE OF CONTENTSTABLE OF CONTENTS viii Each section has a detailed Table of Contents or Index starting at the page indicated FASTENERS 1517 • TORQUE AND TENSION IN FASTENERS • INCH THREADED FASTENERS • METRIC THREADED FASTENERS • HELICAL COIL SCREW THREAD INSERTS • BRITISH FASTENERS • MACHINE SCREWS AND NUTS • CAP AND SET SCREWS • SELF-THREADING SCREWS • T-SLOTS, BOLTS, AND NUTS • RIVETS AND RIVETED JOINTS • PINS AND STUDS • RETAINING RINGS • WING NUTS, WING SCREWS, AND THUMB SCREWS • NAILS, SPIKES, AND WOOD SCREWS THREADS AND THREADING 1802 • SCREW THREAD SYSTEMS • UNIFIED SCREW THREADS • CALCULATING THREAD DIMENSIONS • METRIC SCREW THREADS • ACME SCREW THREADS • BUTTRESS THREADS • WHITWORTH THREADS • PIPE AND HOSE THREADS • OTHER THREADS • MEASURING SCREW THREADS • TAPPING AND THREAD CUTTING • THREAD ROLLING • THREAD GRINDING • THREAD MILLING • SIMPLE, COMPOUND, DIFFERENTIAL, AND BLOCK INDEXING GEARS, SPLINES, AND CAMS 2122 • GEARS AND GEARING • HYPOID AND BEVEL GEARING • WORM GEARING • HELICAL GEARING • OTHER GEAR TYPES • CHECKING GEAR SIZES • GEAR MATERIALS • SPLINES AND SERRATIONS • CAMS AND CAM DESIGN MACHINE ELEMENTS 2310 • PLAIN BEARINGS • BALL, ROLLER, AND NEEDLE BEARINGS • LUBRICATION • COUPLINGS, CLUTCHES, BRAKES • KEYS AND KEYSEATS • FLEXIBLE BELTS AND SHEAVES • TRANSMISSION CHAINS • BALL AND ACME LEADSCREWS • ELECTRIC MOTORS • ADHESIVES AND SEALANTS • O-RINGS • ROLLED STEEL, WIRE, SHEET-METAL, WIRE ROPE • SHAFT ALIGNMENT MEASURING UNITS 2651 • SYMBOLS AND ABBREVIATIONS • MEASURING UNITS • U.S. SYSTEM AND METRIC SYSTEM CONVERSIONS INDEX 2701 INDEX OF STANDARDS 2789 INDEX OF INTERACTIVE EQUATIONS 2801 INDEX OF MATERIALS 2807 INDEX OF ADDITIONAL CONTENT ON THE CD 2854 ADDITIONAL ONLY ON THE CD 2865 • MATHEMATICS • MECHANICS AND STRENGTH OF MATERIALS • PROPERTIES, TREATMENT, TESTING OF MATERIALS • DIMENSIONING, GAGING, MEASURING, INSPECTION • TOOLING AND TOOL MAKING • MACHINING OPERATIONS • MANUFACTURING PROCESS • FASTENERS • THREADS AND THREADING • GEARS, SPLINES, AND CAMS • MACHINE ELEMENTS • ADDITIONALTABLE OF CONTENTS 1 NUMBERS, FRACTIONS, AND DECIMALS 3 Fractional Inch, Decimal, Millimeter Conversion 4 Numbers 4 Positive and Negative Numbers 5 Sequence of Operations 5 Ratio and Proportion 7 Percentage 8 Fractions 8 Common Fractions 8 Reciprocals 9 Addition, Subtraction, Multiplication, Division 10 Decimal Fractions 11 Continued Fractions 12 Conjugate Fractions 13 Using Continued Fraction 14 Powers and Roots 14 Powers of Ten Notation 15 Converting to Power of Ten 15 Multiplication 16 Division 16 Constants Frequently Used in Mathematical Expressions 17 Logarithms 17 Natural Logarithms 18 Imaginary and Complex Numbers 19 Factorial 19 Permutations 19 Combinations 20 Prime Numbers and Factors ALGEBRA AND EQUATIONS 30 Rearrangement of Formulas 31 Principle Algebraic Expressions 32 Solving First Degree Equations 32 Solving Quadratic Equations 33 Factoring a Quadratic Expression 34 Cubic Equations 34 Solving Numerical Equations 35 Series 35 Derivatives and Integrals GEOMETRY 37 Arithmetical & Geometrical Progression 40 Analytical Geometry 40 Straight Line 43 Coordinate Systems 46 Circle 48 Ellipse 51 Spherical Areas and Volumes 54 Parabola 54 Hyperbola 66 Areas and Volumes 66 The Prismoidal Formula 66 Pappus or Guldinus Rules 67 Area of Revolution Surface 67 Area of Irregular Plane Surface 68 Areas of Cycloidal Curves 68 Contents of Cylindrical Tanks 70 Areas and Dimensions of Figures 76 Formulas for Regular Polygons 77 Circular Segments 80 Circles and Squares of Equal Area 81 Diagonals of Squares & Hexagons 82 Volumes of Solids 88 Circles in Circles and Rectangles 93 Circles within Rectangles 94 Rollers on a Shaft SOLUTION OF TRIANGLES 95 Functions of Angles 96 Laws of Sines and Cosines 96 Trigonometric Identities 98 Right-angled Triangles 101 Obtuse-angled Triangles 103 Degree-radian Conversion 105 Functions of Angles, Graphic 106 Trig Function Tables 110 Versed Sine and Versed Cosine 110 Sevolute and Involute Functions 111 Involute Functions Tables 115 Spherical Trigonometry 115 Right Spherical Trigonometry 117 Oblique Spherical Trigonometry 119 Compound Angles 121 Interpolation MATHEMATICSTABLE OF CONTENTS 2 MATHEMATICS MATRICES 122 Matrix Operations 122 Matrix Addition and Subtraction 122 Matrix Multiplication 123 Transpose of a Matrix 123 Determinant of a Square Matrix 124 Minors and Cofactors 124 Adjoint of a Matrix 125 Singularity and Rank of a Matrix 125 Inverse of a Matrix 125 Simultaneous Equations MANUFACTURING DATA ANALYSIS 128 Statistics Theory 128 Statistical Distribution Curves 128 Normal Distribution Curve 128 Statistical Analysis 130 Applying Statistics 130 Minimum Number of Tests 130 Comparing Average Performance 132 Examples 133 Machinability and Hardness ENGINEERING ECONOMICS 134 Interest 134 Simple and Compound Interest 135 Nominal vs. Effective Interest Rates 136 Cash Flow and Equivalence 137 Cash Flow Diagrams 139 Depreciation 139 Straight Line Depreciation 139 Sum of the Years Digits 139 Double Declining Balance 139 Statutory Depreciation System 140 Evaluating Alternatives 140 Net Present Value 141 Capitalized Cost 142 Equivalent Uniform Annual Cost 143 Rate of Return 143 Benefit-cost Ratio 143 Payback Period 143 Break-even Analysis 146 Overhead Expenses
مقسم ومرفوع على جزأين جزء أجزاء كلمة سر فك الضغط : books-world.net The Unzip Password : books-world.net أتمنى أن تستفيدوا منه وأن ينال إعجابكم رابط تنزيل كتاب Machinery's Handbook 29th Edition
