hbk akram مهندس فعال جدا
عدد المساهمات : 275 التقييم : 621 تاريخ التسجيل : 15/10/2012 العمر : 35 الدولة : egypt العمل : student الجامعة : benha
| موضوع: مشروع تخرج عن Design The Belt Conveyor الإثنين 16 سبتمبر 2013, 12:26 am | |
أخوانى فى الله أحضرت لكم مشروع تخرج عن Design The Belt Conveyor Graduation Project
Chapter 1 Calculation Design Schematic Drawing Of Our Belt Conveyor Objective Of The Project Motor selection Calculation The Speed From Equation Selection of reducer’s transmission ratios There are four stages speed reductions Design Summary Design of the coupling - Check Flange Thickness Bolt Design Key check Rectangular key Chapter 2 Calculation Design Design of the second reduction stage (First Gear) 2- Dynamic load ( Kv ) 3- Size Factor (Ks) 4- Load Distribution Factor (Km) 5- Rim Thickness Factor (Kb) 6- Geometry factor (J) 1- Reliability Factor (KR) 2- Thermal Factor (KT) 3- Life Factor (Yn) 4- AGMA Bending Strength (St) Fourth step: - Contact Stress check 1- Elastic coefficient Factor (Cp) 2- Surface Condition Factor (Cf) 3- Geometry Factor (I) 2- Hardness Ratio Factor (CH) Design of the second reduction stage (Second Gear) Second step: - Bending Strength Check 2- Dynamic load ( Kv ) 4- Load Distribution Factor (Km) 5- Rim Thickness Factor (Kb) 6- Geometry factor (J) Third step: - Dynamic Strength Check 1- Reliability Factor (KR) 2- Thermal Factor (KT) 3- Life Factor (Yn) 4- AGMA Ben ding Strength (St) Fourth step: - Contact Stress check 1- Elastic coefficient Factor (Cp) 2- Surface Condition Factor (Cf) 3- Geometry Factor (I) I = for external Gears Fifth Step: - Dynamic Contact Stress Check 3- Life Factor (Zn) 4- Hardness Ratio Factor (CH) AGMA Contact Strength (Sc) Design of the second reduction stage (Third Gear) First Step:- For uniform power source (motor) and moderate shock Second step: - Bending Strength Check 5- Dynamic load ( Kv ) 4- Size Factor (Ks) 5- Load Distribution Factor (Km) 5- Rim Thickness Factor (Kb) Third step: - Dynamic Strength Check 5- Reliability Factor (KR) 6- Thermal Factor (KT) 7- Life Factor (Yn) 8- AGMA Ben ding Strength (St) Fourth step: - Contact Stress check 6- Elastic coefficient Factor (Cp) 7- Surface Condition Factor (Cf) 8- Geometry Factor (I) Fifth Step: - Dynamic Contact Stress Check AGMA Contact Strength (Sc) Design of the second reduction stage (Four Gear) First Step:- For uniform power source (motor) and moderate shock Second step: - Bending Strength Check 6- Dynamic load ( Kv ) 3- Size Factor (Ks) 4- Load Distribution Factor (Km) 5- Rim Thickness Factor (Kb) 6- Geometry factor (J) Third step: - Dynamic Strength Check 9- Reliability Factor (KR) 11- Life Factor (Yn) 12- AGMA Ben ding Strength (St) Fourth step: - Contact Stress check Fifth Step: - Dynamic Contact Stress Check Chapter 3 Calculation Design Design of the First shaft Shaft Material Selection For All Shaft Bearing Selection Design of The Second Shaft Bearing Selection Design Of The Third Shaft Bearing Selection Design of the Four shaft Design Of The Five Shaft Bearing Selection Chapter 4 drawing
كلمة سر فك الضغط : books-world.net The Unzip Password : books-world.net أتمنى أن تستفيدوا من محتوى الموضوع وأن ينال إعجابكم رابط من موقع عالم الكتب لتنزيل مشروع تخرج عن Design The Belt Conveyor رابط مباشر لتنزيل مشروع تخرج عن Design The Belt Conveyor
عدد المساهمات : 18660 التقييم : 34550 تاريخ التسجيل : 01/07/2009 الدولة : مصر العمل : مدير منتدى هندسة الإنتاج والتصميم الميكانيكى
| موضوع: رد: مشروع تخرج عن Design The Belt Conveyor الإثنين 16 سبتمبر 2013, 7:10 pm | |
جزاك الله خيراً وبارك الله فيك وجعله فى ميزان حسناتك |
mohammed altarek مهندس تحت الاختبار
عدد المساهمات : 3 التقييم : 5 تاريخ التسجيل : 02/10/2016 العمر : 23 الدولة : سوريا العمل : طالب الجامعة : جامعة دمشق
| موضوع: رد: مشروع تخرج عن Design The Belt Conveyor الأحد 05 مارس 2017, 11:57 pm | |
السلام عليكم أخي جميع الروابط على موقع عرب شير لا تعمل اذا ممكن رابط ل belt conveyor وجزالك الله كل خير |
كريم محمد المصرى مهندس تحت الاختبار
عدد المساهمات : 1 التقييم : 1 تاريخ التسجيل : 16/04/2017 العمر : 34 الدولة : مصر العمل : مهندس ميكانيكا الجامعة : المنوفية
| موضوع: رد: مشروع تخرج عن Design The Belt Conveyor الأحد 16 أبريل 2017, 6:27 pm | |
motwkel hamad مهندس تحت الاختبار
عدد المساهمات : 1 التقييم : 1 تاريخ التسجيل : 30/04/2017 العمر : 38 الدولة : السعودية العمل : مهندس ميكانيكا الجامعة : نيالا
| موضوع: رد: مشروع تخرج عن Design The Belt Conveyor الأحد 30 أبريل 2017, 12:25 pm | |
تدعب تسجل وتدخل وفي الأخير روابط لاتعمل |
